Unable to save my file
I am unable to save my work in revit to a rvt. I keep getting the message "file.rvt contains an incorrect schema" Please Help!
Kimtaurus
This error can be introduced to file when you copy or save files, and part of the file gets corrupted due to network or hardware issues.
This can also happen with mirroring services such as Box or Dropbox, if you try to access a file which has not yet fully been mirrored.
Several possible solutions:
1. First purge your model (Manage > Purge Unused), then save as.
2. Open a new instance of Revit, open your file (without the new changes) with an audit. Paste your changes into this file and save as.
Also check out this forum post :'Incorrect Schema' Error...
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Jacob.westergaard
Autodesk Support
Autodesk Support
Thank you for taking your time to write this in the forum,
There are various reasons for file corruption, it's a general thing with all kinds of files. However, there are some areas that are more common than others, such as:
  • Read/write failure to the storage media.
  • Program crashes (especially when writing data to the RVT model).
  • An add-in that modifies elements in ways not possible or desired through the normal UI.
  • Untested operations or series of operations (e.g. cancelling a synchronize, or using the Undo command after synchronizing).
Throughout the lifespan of Revit 2015 we have 14 updates where each one of them contributes to a functioning product. So if you haven't already, I would check that every single user is running the latest version and this applies to all our products - the Autodesk Desktop App will notify you every time there's a new update - it will be the same for whatever release you may be using.
Note: Updating will not correct already corrupt files.
As to you specific file, if you want I would be more than happy to go through the file and correct whatever might cause conflict.
I will just need you to confirm and I'll send you a link to a folder where you can upload your file.
In any case let me know how you would like to proceed,
Thanks again, have a great week,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
I was unable to save file in autocad 2010 64bit
