I want to rotate a girdrer such that it will become inclined. But as soon as i want to rotate it an error occur saying that "Can't draw because Work Plane is at a very sharp angle in this view. Go to another view or redefine the Work Plane."
Looking for your co-operation
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Can you set the Workplane in the view you are trying to rotate the girder?
Edit - retry placing the Girder. When I tried, both options were available.
I can't seem to replicate it. A girder can be adjusted without any problems.
Good question. Can you share a file? Easiest thing - CTRL-C and CTRL-V your girder and its supports to a blank file and share.
I modeled the girder by making its family !!!! The already present families are showing this option but the families which I modeled are not showing these options
You need to create the family from the structural framing family template, not the generic model template. See attached.
