I'm trying to render a 3d view to include on a sheet, however I'm having difficulty rendering the desired region.
Attachment "001" shows the region I'm trying to render, and attachments "002" and "003" show the results. I've tried changing the DPI resolution, ticking & un-ticking the region selection, and changing the scale of the drawing, however no luck. Selecting the "Screen" resolution seems to result in a region closer to what I need, however the rendered view is still slightly misaligned, and also the resolution is too low compared with what I'm desiring.
Thanks in advance.
interesting, haven't seen that happen before. usually it will render what is in the window. can you post the file for us to look at?
also i'm assuming when you render, you are only getting one rendering and not 4-6 images as shown :-)?
Howard Munsell
Hi @hmunsell , I no longer require help for this as I applied a work-around. I instead used the "realistic" views and altered the "Graphic Display options". The attached was achieved.
But yes the render did display 4-6 images. I could manipulate this by changing the DPI resolution and changing the scale of the drawing, however I wasn't able to achieve the desired view I wanted.
