Unable to recover back up and original Revit file
1 ANTWORT 1
Nachricht 1 von 2
174 Aufrufe, 1 Antwort
I was working on my Revit project and then closed it. After opening it up again after an hour, I received an error message and Revit has been unable to open any backup file. I have tried to open it through auditing and gone through other methods to recover the corrupt file but nothing seems to work.
1 ANTWORT 1
Nachricht 2 von 2
Sahay_R
als Antwort auf: Anonymous
@Anonymous - you have been able to open the file, right? To start with -
1) delete TEMP files
https://rvit.wordpress.com/2016/01/25/quick-tip-the-temp-folder/
2) clear JOURNALS folder
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2019/ENU/Revit-GetStarted/files/GUID-477C6854-2724-4B5D-8B95-9657B636C48D-htm.html
I would follow these steps first, and then attempt to open the project again. If that is successful, then the following to clean it totally
3) Follow steps in this resource -
https://knowledge.autodesk.com/akn-aknsite-article-attachments/85707515-90ab-40b8-af88-36fb5d839d96.pdf
If you are unable to open the file at all, I would recommend opening up a service ticket with Autodesk.
https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/web-support
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
