Unable to open workshared model
I am having issues opening workshared models. I receive an error that the .rvt is corrupt and needs to be manually recovered. My coworkers are able to open the same files without receiving the error.
I followed this guide:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I was able to clear around 100GB of space off of my hardrive, and then restart. But still I cannot open it
The second thing I tried was closing the worksets individually and enabling them one at a time. Once I enable the "linked structural" workset, the error appears and I cannot open the model.
Thanks for any advice or help
syman2000
Make sure you and your coworker have the same Revit built and update. Next ask your coworker to detach from central and resave the central model. Purge and Audit the file.
I am sorry, I meant to also say that this is happening to multiple files. Not just one file in particular.
syman2000
You have to do the same process - purge and audit each of those link file. Revit is not magic where when you fix one file, it will fix the rest. You constantly need to maintain each file.
