I downloaded a revit family, inserted it into my revit library, loaded the types i wanted and after attemping to place the lighting component I am unable to edit or move it. It is greyed out also the component does not show up in 3D view. I have uploaded screen casts of what is going on. Highlighted are areas where the light should be present.
I got 33 guesses. Post the file and I bet I can narrow it down to one or two.
The revit famililes can be found here:
https://www.bimobject.com/en-us/solar/product/solarlight_informat
https://www.bimobject.com/en-us/solar/product/lq60_ii_builtin
If the problem is the way i loaded the family any advice on how to properly load/insert a family and utilize it in revit would be much appreciated! thank you!
I'd like to look at your file to see how you placed them. I will say that "Lighting_Ceiling-Mounted_Solar_Informat.rfa" is usual in the fact that it is Level Hosted, rather than Ceiling Hosted or Work Plane Based. So I can understand a little difficulty working with this one.
