I can’t load the family into the model. Whenever I put furniture into the model, it will get stuck and crash. I have tried many methods. I also tried to put the furniture in the original file library. If I use the original furniture that comes with the system, it won’t get stuck or crash. Attachment: stuck picture
share your family so we can check. thanks
Try nesting your "bad" family into a new Furniture Template and see if you can load that New Family into your Project.
Have you try linking the old project into your new project. Then select the furniture and copy and paste at same location.
I found the same furniture. See if you able to load this into your project.
