Unable to link point cloud in revit 2018
1 ANTWORT 1
Nachricht 1 von 2
283 Aufrufe, 1 Antwort
Hi all,
I am basically trying to open my revit template that had a link to a point cloud which I cleaned in Recap. After I had cleaned it on recap i managed to link it and open it in revit 2018 - However I have now tried to open the same template on another computer (this computer does not have recap downloaded on it) and it says the link to the point cloud is 'not found' the recap file is in the same folder - when I do try to select the correct path of the file using 'reload from' it says the the file maybe corrupt or incompatible. Any help??
Imran Bhuta
1 ANTWORT 1
Nachricht 2 von 2
Revit_Whisperer
als Antwort auf: Anonymous
Are both builds of Revit the same on both computers?
Can you start a project with an out of the box template and link it in?
