Announcements
Unable to join 2 walls. One existing to new. One new to new. All on same phase.
allister_mcrae
allister_mcrae
This is bananas.
I have walls that i would like to join.
1 new phase to existing phase.
1 new to new.
In both cases, they are not connecting. The Join tool is doing "something" as seen in the images where I can enable the join with the little join boxes. But it only goes half way into the other wall - and I am unable to align the end of the one on the right (new) to the existing on the left. Same story on the new to new.
They are all set on Level 0
Any advice leading to solution/better workflow is appreciated.
With the new to new corner,
RDAOU
@allister_mcrae
Use Allow Join ...its this small T shaped icon next to the end of the wall when selected (if they do not finish up properly from the first instance, drag one back then re-trim them as shown below)
and fix your phases...Manage >> Phases >> Select Demolition & Combine/Merge with next
