Hey there,
every time when I try to run/add Revit Add-In to the version I have which is Autodesk Revit 2018.3 it shows me this msg:
This application requires a 64 bit version of Autodesk Revit. Please install Revit then run this installer again!
Then the process ends without success!
As far as I know, Revit 2018 works only with 64 bit!
Thank you in advance!
.... which Revit Add-In are you refering to ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
It is Revit Add-in from Knauf
here it is (the first one in the list):
.... looks like is an issue from Knauf plug-in
... sorry ... I guess you have to contact them and ask them directly why is it not running?
aRcHiTeCt.JM
REVIT EXPERT ELITE
this is not a revit issue but a 3rd party add in issue
its best to contact them for addtional help
DarrenP
