Unable to install Revit 2019 student version
hello good afternoon, I am a student and install the version of revit 2019, the revit is not executed and this message appears.
the input point of the _cexit procedure is not found in the dynamic link library c: \ Program Files \ Autodesk \ Revit2019 \ interface.dll.
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! I see that you are a new visitor.
Please see the steps for installing student software
Which download method did you choose?
the method I chose is the same as it appears, in fact I have installed the 2014 version of revit, that I had not previously mentioned, the problem that persists is that I can not open the program one time it is installed. I have a question will I have to uninstall the 2014 version and the 2019 version and reinstall the revit 2019?
Viveka_CD
Hi @Anonymous
Not necessary to uninstall Revit 2014, but please make sure you have the system requirements are compatible for Revit 2019 and hardware tools are certified as well.
Let me know if you have questions on this.
Considering you have 2014....does your computer meet the 2019 workstations specs?
Viveka_CD
Hi @Anonymous
I'm checking back to see if you've made progress with the installation and if the recommendations helped?
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
jarnautovic00
Observer
Observer
I got student license but when i try to install Revit 2021 this happens: first picture with install method, and second with download. 2020-11-30.png2020-11-29 (4).png
