unable to export to IFC
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
923 Aufrufe, 5 Antworten
I am having a problem with exporting my revit file into IFC.I have already downloaded IFC for Revit 2016. I click on export to IFC and I can see the window opens, because I can see it when I move my mouse on top of the Revit icon, however it does not show on my screen. I tried to uninstall and install IFC for Revit and it is still not working.
This is the first time I am having this issue as previously I was able to export to IFC with no problem.
Tags (2)
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: Anonymous
Possibly previous dual monitor?
You might try the following:
-Update drivers graphics card.
-Update Revit.
-Remove other, possibly conflicting, add-ins from Revit
-Reset settings to default.
If you have an NVIDIA card, sometimes NVIDIA Desktop Manager has caused problems
Disable the Nvidia Desktop Manager:
-Right click on desktop  and select nView properties
-Select "Desktop Management" tab.
-Under "nView Desktop Manager", select the "Disable" button.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! Smiley (fröhlich)
As the first step can you confirm if you've installed the latest updates for your Revit version?
Nachricht 4 von 6
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Did you try the updates?
Can you share a file to test further?
Nachricht 5 von 6
als Antwort auf: L.Maas
The problem ended up being dual monitor....
Thanks for helping!
Nachricht 6 von 6
Viveka_CD
@Anonymous
Thanks for getting back to us! Glad to hear the issue is resolved :leicht_lächelndes_Gesicht:
Happy Friday!
