unable to export Revit - Enscape model to Unity with all textures
10 ANTWORTEN 10
Nachricht 1 von 11
lucia.benkovicova
645 Aufrufe, 10 Antworten
Hello, I am unable to export the 3rd model from the top available to download here with all textures - Enscape ones applied to the surroundings of the central building are missing: https://enscape3d.com/free-sample-projects/. I have used the Simlab fbx export plugin for Revit. I would like to get the model into Unity with all textures of the exterior. I have tried it with Revit 2020 as well as 2023.
10 ANTWORTEN 10
Nachricht 2 von 11
mphungDCHNW
als Antwort auf: lucia.benkovicova
If your trying to see the textures material you have created in Revit make sure your detail level is set to fine alongside that make sure you can even see the textures within Revit itself.
Nachricht 3 von 11
I have not created any materials, but it is true that I do not see all the materials in the 3D view, just in Enscape. Where exactly should I check the detail? I am a beginner to Revit.
Nachricht 4 von 11
mphungDCHNW
Well there's your problem since you haven't created any material and you have the default ones your just going to see the default ones in Enscape and there just going to look a little more crisp with the graphic from the lighting.
Nachricht 5 von 11
You must create different Materials, each Material should have its unique Appearance Asset in Revit so that you can export the model to Enscape and view/re-assign texture in Enscape properly.
https://iastate.pressbooks.pub/visualgraphiccomm/chapter/chapter-19-introduction-to-enscape/
Nachricht 6 von 11
lucia.benkovicova
als Antwort auf: mphungDCHNW
I don't get it, in Enscape it looks stunning, doesn't seem to be any defaults to me; have you opened that model sample?
Nachricht 7 von 11
lucia.benkovicova
als Antwort auf: ToanDN
why? there are materials in the Revit sample model and the textures are already assigned to it in Enscape
Nachricht 8 von 11
Nachricht 9 von 11
mphungDCHNW
Alittle confused on what you mean you said that you have assigned materials in Revit or have at least some type of texture designs what are you trying to see in Enscape then??
Nachricht 10 von 11
lucia.benkovicova
Yes, I have Enscape installed in Revit 2020 and 2023.
Nachricht 11 von 11
lucia.benkovicova
I have a sample Revit model which is already ready-made for Enscape. I just want to export it and use it in Unity. But when I export it, the Enscape textures are missing.
