Unable to download Revit 2020
3 ANTWORTEN 3
Nachricht 1 von 4
qixing.chenNYA88
223 Aufrufe, 3 Antworten
I tried to download Revit 2020 and run the download file as an administrator. It shows installation incomplete. I also checked on Browser download, but the webpage in blank. Could anyone give me some guidance to solve this issue?
Thank you for your help!
3 ANTWORTEN 3
Nachricht 2 von 4
mphungDCHNW
als Antwort auf: qixing.chenNYA88
You may want to check how much disk space you have along with running it as a admin uninstalling what you have and re installing it.
Nachricht 3 von 4
qixing.chenNYA88
als Antwort auf: mphungDCHNW
Thank you for your response. There are enough spaces and I have cleaned up
the temp file. But it still doesn't work.
Nachricht 4 von 4
rxi.gg
Any problem with your internet?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
