I cannot create the landing at the top or else it’ll automatically make one complete looped guardrail around the entire stair, and I only need the guardrail in certain spots, like shown in the screenshot. What is shown in red are the only three things I need to add still. My problem is when I sketch a path for a new guardrail while I'm on the 2nd floor and try hosting it to the stair, it automatically defaults to the 1st floor stringer instead of the 2nd floor stringer. Same with the handrail on the wall, it won't host to the floor I want it to, it will host down below. I've tried copy and pasting it to selected levels & it wasn't working either. Anyone have any suggestions?
You can delete flight railing, you can host new flight railing and you modify flight railing -- so I'm not understanding what's not happening for you. Are you unpinning?
...post your file.
hello, post only your staircase here so we can check. thanks
Hi @DanLevi2759
Welcome to the Revit Architecture forum! ![]()
Please share your model and the community will be able to offer further feedback.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
