I've imported a 3D .dwg export from 3dsMax into Revit but I am unable to change the material. I've gone through object styles and changed the material but nothing changes.
Attached is the .dwg file if needed
Does this mean this is just my display settings, in the image I was using Realistic
No. I had to fix the DWG, the color of the handrail wasn't By Layer.
