I have a track light family that I've put in a revit project. However when I put it in, its always at the same height from the FFL. I want it to be higher up from the FFL but no matter what i do i cant seem to adjust it. how do i fix it?
you need to edit your track light family and check the sill height dimension setting or post your family here so we can check. thanks
It's probably a Level-Hosted Family. If so, enter a distance value into the Light Fixture's "Elevation From Level" or "Offset From Host" Instance Parameter. But before you go there, confirm that there is not a Type or Instance Parameter that controls the light elevation.
If it is a non host family then go to an elevation view, move up or down with Disjoint box checked.
I know it is so late but i put for other seekers ![]()
uncheck this one in the family and every thing going good, BUT, you will lose the rotation ![]()
