Unable to add a 4x4 wood post???
micah
micah
Why can't I add a 4x4 post?
https://msacloud.egnyte.com/dl/BB7d0Dgv2E
RDAOU
Most probably you started a structural column but trying to load an architectural column family (or vise versa)
There are two folders for posts/columns. One is simply called Columns and the other is called Structural Columns … make sure you are loading from the right one
micah
How do I load an architectural post? When I click columns they seem to only
be structural.
Sincerely,
*Micah D. Smith, AIA*
Architect
* MS*|*A*
Mobile: 805-704-7118
micah@msmith-arch.com
msmith-arch.com
San Luis Obispo, CA
RDAOU
@micah
When you go to architectural tab > Columns and click the drop down arrow, you should have both options Structural and Architectural
see this YouTube for more info https://youtu.be/DpOsdyqzKE0?si=tw0_Dsdcq_iryX7C
I don't think an architectural column is appropriate here. Turn on Structural Columns category and place a structural column:
When adding a structural column in a floor plan, play attention to the option bar and you want to change from Depth to Height.
