unable to active dims
linkboy
linkboy
In attahed plan(2016 ver.), CMU shaft was unable to active temp dimenstions in related to grids. They can be mutipliy selected but not able to active the option "active dimensions".
Thanks!
ennujozlagam
hi, i tried in revit 2014 and revit 2015 i can activate dimensions but not in Revit 2016. it could be a bug? thanks
linkboy
Thank you! I had issues to save down the file to IFC. It lost all grids when I opened in 2015. Can you share how to save down and keep the BIM info as much as possible in this case?
ennujozlagam
ok, try and download and installed latest version for ifc for revit 2015
https://apps.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3Aifc2015_windows32a...
Take a look some issues with ifc
https://www.augi.com/library/myth-buster-revit-ifc
