Hi you all
It is probably a silly fix but it has been a long busy day, I need to head out in a few minutes and I am not able to think of anything.
I am sure I was working on this project earlier in the morning before I left to site and came back to find that we are not able to activate any view on the sheets no...double click seems to be broken as it does nothing
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Most probably they are pinnedand you forgot to enable Select Pinned
Alternatively... check if the view ports are hidden. This would also prevent you from selecting the view on sheets to activate.
Check and see if someone hide the view by element on sheet. Use this to see if there are object hidden.
