Unable to Access the Model while adjusting elements
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
!Dalton_Goodwin!
1058 Aufrufe, 3 Antworten
This is the warning that people are reciving when they try and move items that don't have any ownership?
Not really sure what is going on here. Another thing is when people get this, there is nobody synching.
Any ideas? Help would be much appreciated.
Warning:
The request operation cannot be completed because the model xxx is not currently available.
DaltonG
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: !Dalton_Goodwin!
-Looks like a loss of network connectivity. Check network access--server, all workstations.
-Maybe reboot the server and all local PCs.
-Are you using Revit on a LAN ( local area network)
or with a cloud-sharing system like C4R or Revit Server?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
Corsten.Au
Have you created and working on local file or directly opened the central file ??
Way to check this is, if its a local file, then the file name should show " Filename_your_username" ..
Corsten
Building Designer
Nachricht 4 von 4
!Dalton_Goodwin!
als Antwort auf: cbcarch
 LAN ( local area network). Which seems to be the problem. The connection is being lost periodically through the day it seems like. I was thinking I should only see that warning during a synch.
