Unable to Access the Model Warning
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
vitorbortoncello
279 Aufrufe, 2 Antworten
When trying to open a model with multiple links, this warning appears (i am not using worksharing)
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: vitorbortoncello
do you posses the link file that the current model is seeking, and not on a different server? try to open and audit the link file and reload again and see if helps
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Error-Model-...
Nachricht 3 von 3
Hi @vitorbortoncello,
This message often comes up if somebody is opening the that model referenced in the Message.
If that user encounters a similar message and leaves it open, that model will be 'locked' and nobody can access it unless it's completely opened.
On workshared models this also happens if a model is being syncronized and somebody loads that model as a link, You get this warning and continues when the sync is done.
