Un-editable Curtain Panels (as part of curtain wall)
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1899 Aufrufe, 4 Antworten
I have a curtain wall 'gridshell' type structure that was originally a mass and then had curtain panels (in the triangle - flat pattern format) applied to it. I'm not sure what, but something odd has happened and now when you select any of the panels you can't edit or delete them, so you can't create openings etc.
The panels are not pinned, and there are no worksets so definitely editable.
Any help would be greatly appreciated, there is a dropbox link to the file below (large file size).
'Gridshell' Project File
4 ANTWORTEN 4
Nachricht 2 von 5
semko_dm
als Antwort auf: Anonymous
Welcome to the forum!
This is normal behavior. To modify your form or panels you have to select the mass, edit it and there, in "In-Place Editor", you're able to do so.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Nachricht 3 von 5
FGPerraudin
Hi @Anonymous,
@semko_dm is right, edit your mass and you will be able to delete panels.
Be careful though, you have two copies of the same mass at the same location (which adds to the confusion)!!!!
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 4 von 5
FGPerraudin
als Antwort auf: FGPerraudin
Nachricht 5 von 5
Thanks guys, much appreciated. My sleep-deprived brain would not have made that leap!
