un-constraining lines when making a region
11 ANTWORTEN 11
Nachricht 1 von 12
Slamothe
621 Aufrufe, 11 Antworten
I am trying to make a region with un-rectilinear lines, but Revit wants to constrain some of my my lines to horizontal.
Help?
11 ANTWORTEN 11
Nachricht 2 von 12
SteveKStafford
als Antwort auf: Slamothe
You can turn off snaps temporarily, keyboard shortcut SO (stock settings).
Steve Stafford
Nachricht 3 von 12
handjonathan
Hi @Slamothe
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 12
Slamothe
als Antwort auf: handjonathan
It did not help.
Nachricht 5 von 12
mhiserZFHXS
You need to be more specific about your problem then... Post some screenshots at least.
Nachricht 6 von 12
Slamothe
als Antwort auf: mhiserZFHXS
I am trying to draw a line between the end of the 2'-6" line and the end of the 3'-0" line to create a region. The "constraint" won't let me.
Nachricht 7 von 12
Hold ALT when draw the boundary lines.
Nachricht 8 von 12
Slamothe
als Antwort auf: ToanDN
Thanks.
Nachricht 9 von 12
SteveKStafford
Hmm, ALT while sketching doesn't do anything for me. Must be missing something.
Snaps Off (SO) followed by Snap Endpoint (SE) works for me... I left off the second step in my earlier reply, sorry.
Steve Stafford
Nachricht 10 von 12
Slamothe
als Antwort auf: SteveKStafford
Turns out ALT doesn't work when the line reaches a certain length, but SO & SE does work.
Thanks.
Nachricht 11 von 12
Lachlan-JWP
You can also press TAB while hovering the cursor near the endpoint your want to snap to for Revit to cycle through the different snap options.
Nachricht 12 von 12
SteveKStafford
als Antwort auf: Lachlan-JWP
Ordinarily yes, but at the distance described in the image the snap fails to "see" the endpoint. Quirky...
Steve Stafford
