ugrading a model in revit 2009 to 2017
2 ANTWORTEN 2
Nachricht 1 von 3
1230 Aufrufe, 2 Antworten
Revit says my model need to be upgraded from Autodesk Revit 2009 or earlier to 2017. But when I try to upgrade it, it fails to open the document.
2 ANTWORTEN 2
Nachricht 2 von 3
Corsten.Au
als Antwort auf: Anonymous
Are you trying to double click the file and open Revit file?
try to open Revit application first, and then open the file... it should upgrade...
I believe you have more than two revit version installed ..
Cheers
Corsten
Building Designer
Nachricht 3 von 3
Kimtaurus
Also, don't forget to check the Audit box before opening.
If you still have a Revit version between 2009 and 2017, open (and audit) the file there first.
It's best to upgrade an old file in steps.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
