Ugly geometries
5 ANTWORTEN 5
Nachricht 1 von 6
583 Aufrufe, 5 Antworten
Ugly geometries
Could someone please explain why do I get such an ugly geometry for all door handles?
I tried export to FBX, FBX with LOD, IFC, same results.
Is there a way to fix this? or get better geometries using Revit API?
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
RobDraw
als Antwort auf: Anonymous
Is that native Revit content or is it imported?
Rob
Nachricht 3 von 6
martijn_pater
als Antwort auf: RobDraw
Triangulated geometry, obviously imported... I hope.
Nachricht 4 von 6
It is native Revit.
I've just discovered that when I export FBX from Revit API with the following parameters:
UseLevelsOfDetail=True, LevelsOfDetailValue=15, it looks much better.
(BTW, where I could find LOD value in Revit manual export? I can see only LOD checkbox.)
Anyway, I'd need IFC in this quality. How can I achieve the same with IFC?
Do I understand it right that Revit describes geometry only as "curve from here to there" and the faces are then calculated (triangulation)?
Nachricht 5 von 6
martijn_pater
ow nvm you were showing the export (obviously), thought it was a Revit view.
Nachricht 6 von 6
als Antwort auf: martijn_pater
Yes, that was already export, sorry about that. Here's how it looks in Revit:
