UCS Origin Showing
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
JamesMcKinnon
2084 Aufrufe, 4 Antworten
UCS Origin Showing
Hello, I have somehow managed to get the UCS origin point showing in Revit.
I had to update the project & survey base points within a project. Both are hidden within most of our view templates, so I revealed hidden elements and the UCS origin appeared alongside both base points. After modifying the project & survey base points I turned "reveal hidden elements" off and the UCS remained on the screen.
The point is still there after playing around with various settings and restarting Revit. It wouldn't be a big issue, except for that it counts as an element within a viewport on a sheet and all of my plots are shifted accordingly.
Has anyone dealt with this issue before?
-James M.UCS in top leftUCS in top left
4 ANTWORTEN 4
Nachricht 2 von 5
bin
als Antwort auf: JamesMcKinnon
Crop Region?
Nachricht 3 von 5
That happens with the latest update. Turn off: Site > Internal Origin.
Nachricht 4 von 5
JamesMcKinnon
als Antwort auf: ToanDN
Thank you!
Nachricht 5 von 5
mari.de-jagerBY4DR
I have this same issue, where do I find the "Site" tab I cant see anything under "massing and site"
