Typo in Revit 2027 Rule-Based Numbering dialog ("Snotch" instead of "Scope")
h_echevarria
h_echevarria
In the Rule-Based Numbering feature (Manage → Numbering), the heading above Filter, Filter Categories and Numbering Parameter is displayed as "Snotch".
Based on the functionality and Autodesk documentation, this appears to be a typo and should likely be "Scope".
Revit Version: 2027.2
Steps to reproduce:
  1. Open Revit 2027.
  2. Go to Manage → Numbering.
  3. Create or edit a numbering template.
  4. Observe the section heading above Filter, Filter Categories and Numbering Parameter.
Expected result:
  • Heading displays "Scope".
Actual result:
  • Heading displays "Snotch".
Basam.Yousif
You mean this?
What build are you running?
Thought maybe it was the 'dark mode' ...
h_echevarria
Exactly, I am referring to that. In my first post, you can see it in the image.
I have this version
It is not a huge problem, but I was trying to learn how to use the dialogue, and "Snotch" was confusing.
I was trying to report this back to Autodesk, but I'm not sure where to do it, so I created this post.
