If you use Shape Editing for your roof instead it will tolerate the transition between roof elements better. You'll get a warning about extreme shape editing not creating faithful thickness forms though.
Steve Stafford
From what I see, you can create it as 2 roofs by extrusion, side by side, then join them. Then the transition between slope changes can be ironed out.
@SteveKStafford: is that one or two roofs?
I just tried as one and couldn't get there. Posted on OP's dup thread.
They are all separate (each "slab"), but the same type. If they were really building that it won't be that simple. The upper roof will overhang the lower so it can support a wall to infill between roof elements etc.
Steve Stafford
