I am trying to make a two level based generic model family, and I have a problem with setting upper level constraints.
I see that I have to specify the elevation for the upper level; instead, I want upper level to automatically hosted to a level above in my project. So when I change base level, top level follows the level above. Is there way I can do that?
You can set the view range for the lower level above the upper level to see geometry there. You can set your workset to the upper level to host geometry to that i.e.
