Hi, I'm hoping someone can shed some light on an issue I'm having with the Direct link tool for Twinmotion for Revit.
I have just updated my Revit to Revit 24.2 and Twinmotion to 2023.2.2 (the latest versions) and for some reason, my direct link is broken.
If I select open in Twinmotion from the Revit view tab, Twinmotion will open, but then not show the imported model.
Even after this, in Twinmotion if I go to Import --> Direct Link, it says “No Source Available”. Even after I had selected direct link in Revit.
How can I fix this?
Hi @joshua_s2V9T2
Thanks a lot for posting your question to the forums! Im tagging @ryan.duell, who may be able to advise.
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Hi all,
Revit and Twinmotion do have intended\supported versions, as follows:
Revit 2024.2 is compatible with Twinmotion 2023.2.
Now, there are some known limitations with direct link that we could be running up against here; please confirm the items from this page:
Known Issues for Twinmotion and Revit 2024 Interoperability
Hi Ryan, thanks for that.
Somehow the issue resolved itself and I am now able to direct link with no issue... Must've been an issue with the file or something?
