Twinmotion Animation - Section Box Phased
1 ANTWORT 1
Nachricht 1 von 2
nicebikemate
239 Aufrufe, 1 Antwort
Hi All,
I'm trying to create an animation that uses a section box to cut through an existing building, whilst the proposed alterations aren't affected. I've been trying to do this using view sets and phases but not really having any luck. Any thoughts?
Cheers
1 ANTWORT 1
Nachricht 2 von 2
andrew8QEC8
als Antwort auf: nicebikemate
You could potentially export two or more (depending on the number of phases) 3D different views as separate datasmith files, then use a section box (the one in Twinmotion) and apply a translator or animation path to that Twinmotion section box. Then for phasing the video you use different cameras with different layers on and off. I would also recommend posting the question to the Twinmotion forum.
