Twinmotion add in for revit doesn't show up?
poput
Message 1 of 18
poput
I installed the Twinmotion for Revit but in doesn't show up in my navigation.
I looked in the add in folder and the twinmotion folder is in there, I also tried to uninstall/install it but with no result.
Hope somebody can help me,
best regards,
Chris
Replies (17)
Message 2 of 18
DarrenP
do you not see a twin motion tab in your ribbon?
DarrenP
Message 3 of 18
VenB
Should be seen that way:
Message 4 of 18
Which version do you have installed?
Is it a torrent, is it a trial?
I’m using Twinmotion 2019 v2
And happens that with that installation the tab for twinmotiuon is not installing.
But in any case tyou can use both and interact in between them without a problem.
Just export the Revit as CAD or as FBX.
Message 5 of 18
poput
Hello Darren,
yes, normally it should be there, I installed it month ago on an other computer.
Message 6 of 18
poput
hello,
yes I know but it isn't and for the proof, the hole folder is in the revit add in section.
Message 7 of 18
DarrenP
you may need to post on twinmotions forum: https://twinmotionhelp.epicgames.com/s/?tabset-f276c=3
DarrenP
Message 8 of 18
poput
Hey Darren,
Thanks for the link, I saw that somebody else have the problem, hope it will be answered soon.
Is it possible that send me your twinmotion addin folder for Revit?
because I made the mistake to reinstall the plug in also on my other comper. 😅
best regards
Message 9 of 18
poput
hello ana,
Thanks for the advice.
I didn't know that you can export fxb, because I used the twinmotion add in earlier for the export.
I hope the result is the same.
best regards.
Chris
Message 10 of 18
DarrenP
attached
make sure to install the latest add in for revit here: https://www.unrealengine.com/en-US/twinmotion/plugins
DarrenP
Message 11 of 18
poput
Thank you very much!
i tried to put it in, but that wasn't the solution.
hope the will unreal can fix it.
best regards,
Chris
Message 12 of 18
poput
Hey Darren,
is it in the revit addin folder a addin.file for twinmotion?
if yes, could you please send it to me?
best regards,
Chris
Message 13 of 18
DarrenP
there isn't one
DarrenP
Message 14 of 18
roy.waller
Same problem here, no twinmotion ribbon, and no addin
Message 15 of 18
Me neither. I have just installed twinmotion and I cannot find the link in Revit
Message 16 of 18
DarrenP
you will need to post on the twinmotion forum here: https://twinmotionhelp.epicgames.com/s/?tabset-f276c=3
DarrenP
Message 17 of 18
ilir.zaho
Maybe you have to open a 3d view and than you should be able to see it
Message 18 of 18
60017208
Community Visitor
Community Visitor
