Twinmotion 2023.2.3 Directlink not working
1 ANTWORT 1
Nachricht 1 von 2
chris_croton
476 Aufrufe, 1 Antwort
Hey Team,
Has anyone had issues in the last couple of days with the direct link not working after windows updates?
Its been working great until yesterday. We have this on several machines (all HP ZBook Studio G8 and G9 laptops)
With either R2024 or R2025 Twinmotion doesn't pick up any connections to Revit and vice versa.
When trying to do a new connection, picking the ... just brings up a small black box like a cursor and no thing else.
Starting TM from Revit 2024 starts TM but doesn't invoke the directlink import at all.
Any ideas?
I've tried restarting laptops, starting Revit and TM in different versions and also tried the 2024.1 preview version, but still the same issue.
Looks like an issue with windows updates not showing the popup window to select the Revit source in TM.
Could it be Sophos, or MS Defender or firewall settings blocking the link between software?
Cheers
Chris
1 ANTWORT 1
Nachricht 2 von 2
eizinmyat
als Antwort auf: chris_croton
I attached the link about some twin motion connection problem with Revit so that you could check it. I hope it can help you. For Revit 2024, Twinmotion 2023.1 and 2023.2.
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2024-direct-link-to-twinmotion-problem...
https://forums.unrealengine.com/t/revit-2025-and-twinmotion-latest-version/1806964
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-BDD6303D-063C-4B1D-B3B1-6783137FFFD0
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
