Trying to sketch a custom staircase
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
jackzaph
383 Aufrufe, 4 Antworten
REVIT STAIRCASE ISSUE.JPGHi,
So I'm back again with another issue. I am currently trying to sketch a custom staircase (picture) below, but when I click finish it says I cannot create this staircase.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: jackzaph
Run sketch:
Landing sketch:
Set the Run Type to have Underside Surface = Stepped and increase Structural Depth as needed.
Set the Landing type to have a thicker Monolithic Thickness.
Nachricht 3 von 5
jackzaph
als Antwort auf: ToanDN
How did you do this? I just see the picture.
Nachricht 4 von 5
Split into two right angle-shaped sketched Stairs joined together.
Nachricht 5 von 5
See again. And here from your picture.
