Trying to remove vertical curtain wall grids
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
bobbywijya
312 Aufrufe, 4 Antworten
Hey anyone can help me out? I'm trying to remove these Curtain Wall Grids (vertical) I have tried so many times but it won't allow me to do it. I have tried to use add/remove segments but it won't allow me to do that. Can someone please help me out for this problem? I have also attached my Revit file. Thank you
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: bobbywijya
Why do you need to remove the Grid Line?
What about moving it?
...this?
Nachricht 3 von 5
bobbywijya
als Antwort auf: barthbradley
It's part of the design, I have to put double storefront doors. Do you think moving the grid as close as possible to the next mullion will solve the problem, or do you have any other suggestions? Thank you for the response sir.
Nachricht 4 von 5
this?
...yes, just move the grid lines.
Nachricht 5 von 5
bobbywijya
Thank you so much for the solution, Mr. Barth! I thought the same as first to move the gridline to the next mullions.
