Trying to make a parametric door
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
429 Aufrufe, 7 Antworten
I'm trying to make a parametric door. Whenever I try to change the frame width, I get the error shown below.
Constraints not satisfied
Error 1 : Frame/Mullion - Sweep id 5550
Dimension : Linear dimension style :Default linear style : label :frame depth id 7937
Also , I get these types of error whenever I try and flex the door parameters.
Kindly guide.
7 ANTWORTEN 7
Nachricht 2 von 8
syman2000
als Antwort auf: Anonymous
Upload the family so we can analysis it.
Nachricht 3 von 8
als Antwort auf: syman2000
 I have attached  the door file
Nachricht 4 von 8
syman2000
I notice the right side don't have parameter. You have to add the same thing. As well the door knob is locked into unnecessary reference plane. So just remove it and only keep the middle. See attached
Nachricht 5 von 8
MetalFingerz
Hello @Anonymous ,
Regarding your issue, I believe you have it when you're flexing the frame depth ? The problem seems to come from that the dimension is not properly tied to reference planes which leads to constraint issues. If you delete it and carefully tie it to the proper reference planes, the error disappears.
Also, you have a sweep that start on the right side and your Frame width param is on your left side so it is totally ineffective. You need to create your dimension parameter on the side of the profile so it flexes properly.
See the picture attached where the Frame width is on the wrong profile and I could flex Frame depth without errors (it's in millimeters).
Nachricht 6 von 8
als Antwort auf: MetalFingerz
Thank you so much @MetalFingerz.
Your reply solved the issue.
Nachricht 7 von 8
Nachricht 8 von 8
Thank you syman2000.
Your prompt response has helped me .
Im your new subscriber.
