I added revision labels to by revision bubbles and they are not starting at 1. The numbering setting was changed to by sheet.
I have set up my revisions as follows:
REV1 - No numbering
REV2 - No numbering
REV3 - Numeric
REV4 - Numeric
REV5 - Numeric
Say I have 4 sheets with the following revisions on them
Sheet 1 - No revisions
Sheet 2 - Rev 1, 2, 3
Sheet 3 - Rev 1, 2, 3, 4
Sheet 4 - Rev 4
Sheet 5 - Rev 1 ,2, 3, 5
Currently the revision tags show
Sheet 1 - no revision tags
Sheet 2 - Revision tag for Rev 3 labeled as 1
Sheet 3 - Revision tag for Rev 3 Labeled as 1 and Rev 4 labeled as 2
Sheet 4 - Revision tag for Rev 4 Labeled as 2.
Sheet 5 - Revision tag for Rev 3 labeled as 1 and Rev 5 labeled as 3
Sheet 4 - Revision tag for Rev 4 Labeled as 1.
Sheet 5 - Revision tag for Rev 3 labeled as 1 and Rev 5 labeled as 2
Essentially I would like to set up the tags to start at 1 regardless of other sheets.
I am using Revit 2018
U can Update the revisions like this as i shown below, The revisions are will come automatically come when u provided a cloud and assign the revision cloud to the appropriate revision, Revit Automatically detects the last sequence number and it will show current revision as on that
My issue is slightly different. I added a manual revision tab to the revision table however would like the label tag attached to the revision bubble to start at 1. At the moment, every time I add a tag to the bubble it displays 3 instead of starting at 1. I would like to have the revision number start at 1, regardless of revision numbers in the sheet issues/revisions popup window. All revisions on the sheet are under the same revision. I thought that setting the Numbering to Per Sheet would resolve this issue, but it does start the revision number on the sheet at 1.
the revision tag will come to the cloud based on the revision number given to the cloud, please check the revision cloud. Once update the revision clouds revision number and check the tag**
Or else create the manual annotation tag go on with that..
