Trying to delete a Area Scheme
14 ANTWORTEN 14
Nachricht 1 von 15
guilhermebelo
506 Aufrufe, 14 Antworten
I'm trying to delete an Area Scheme in a Revit Project. When i do that instead of just deleting the elements associated to that area scheme it deletes all the areas in the project. In this case i'm using Revit 2024.
Does anyone have any idea of what is doing this?
Beschriftungen (1)
14 ANTWORTEN 14
Nachricht 2 von 15
guilhermebelo
als Antwort auf: guilhermebelo
I was able to resolve the problem by changing the area type of all the areas in the project, deleting the area Scheme, and then changing all the Area Type back. But i'm still not able to understand why it happens.
Nachricht 3 von 15
azad.Nanva
Rename your Area Scheme name to make it customize.
Nachricht 4 von 15
guilhermebelo
als Antwort auf: azad.Nanva
I already tryed that but it didn't work.
Nachricht 5 von 15
azad.Nanva
is it Gross Building , right?
Nachricht 6 von 15
guilhermebelo
No, this is affecting all the Area Schemes.
I already solved the problem, by changing the Area Type of the Areas i want to maintain. Still i'm trying to understand if this is a bug. Because if i want to delete a Area Scheme it shouldn't affect the others.
Nachricht 7 von 15
azad.Nanva
I can't understand your problem and your solution and how solve the deleting problem of area schem with changing the area type ?and what is problem now. deleting , rename or what?
Nachricht 8 von 15
guilhermebelo
The problem is still the same. This is a view where i organize all the area plan and their Schedules.
By deleting one Area Scheme all the areas in the project area deleted.
As you can see in the next image. My aim here is to see if this is a recurrent issue.
Nachricht 9 von 15
azad.Nanva
that you mean, you have area and schedule from TO MAINTAIN 1 and you delete the TODELETE and the schedule and area plan from TO MAINTAIN 1 will be deleted.
Nachricht 10 von 15
azad.Nanva
is this true ?
Nachricht 11 von 15
guilhermebelo
No, only the Areas.
The views and schedules from TO MAINTAIN 1 and TO MAINTAIN 2 are not deleted. Only the AREAS.
I have made somes tests to new models. Like creating new area schemes and deleting them, or creating new area schemes and then upgrade the model from Revit 2022 to 2024. And i not able to recreate the same problem that i'm having.
I'm reaching the idea that the file might be corrupted in some way.
Still, the reason i came here is because it happened to two diferent projects, which can be a recurrent issue. But it can also be a coincidence.
Nachricht 12 von 15
azad.Nanva
English is not my first language,but did you mean when you delete the TO DELETE the AREA PLAN of TO DELETE ,will be deleted,if yes so this is not issue,when you delete the base all the area of this base will be deleted too.this is normal.
Nachricht 13 von 15
guilhermebelo
All Area are deleted from TO MAINTAIN 1, TO MAINTAIN 2 and TO DELETE.
Nachricht 14 von 15
azad.Nanva
could you share your project?
Nachricht 15 von 15
peleassistant
I'm not sure why it does that for you, but trying it with Revit 2024 and using Pele AI to do it is quite easy :leicht_lächelndes_Gesicht:
Check it out:
https://www.youtube.com/watch?v=z9q0485wx00
