Trying to create exterior corner trim with model in place sweep
vanderloo5
vanderloo5
I thought this would work ok but I'm having issues.
I created a profile family and called it corner trim. Loaded it into my project. And when I do a model in place component, I'm picking the corner of the wall as the path, then using my corner trim family profile for the profile. When I get to the end of the process, it all looks like it's going to work.
Then I click finish, and the trim only goes half way up the wall. I can't figure out how to edit it to fix. Is there a better way to create corner trim? Or is there a way to make this go all the way up?
Note that when I select the wall corner as the path, the line does go from top to bottom.
You can use Vertical Wall Sweep or even Architectural Column.
vanderloo5
Thanks ToanDN.
That was the ticket.
