Trying to create a dynamic tag
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Sahay_R
843 Aufrufe, 2 Antworten
I am trying to create an arrow to indicate the direction of a floor pattern for our Interiors department that looks like the attached screenshot. A part of the challenge is to create a dynamic arrow that will size itself per the room that it is dropped in, with label that can be edited to add a particular floor finish. The label works. The dynamic arrow does not. I have tried it as a Generic Tag, Generic Annotation, even tried to modify a Room Tag - none of it worked. What have I missed? Is this possible at all? Is there an alternative solution that will work?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Sahay_R
Create a line based detail component family with a nested generic annotation for the label.
Nachricht 3 von 3
Sahay_R
als Antwort auf: ToanDN
Perfect! It worked! As always - you have been a life saver!
Rina Sahay
