My truss in coarse view looks strange while medium view looks good. Is it possible to display it as red lines I drawed?
Medium View
Coarse View
Gelöst! Gehe zur Lösung
Gelöst von rcsoul. Gehe zur Lösung
Never mind. Found the answer. It can be adjusted by editing corresponding the structural frame.
what you are describing is the different representations of Structural Members based on the Detail Level (e.g. Course, Medium, Fine) of the Project View. What you are seeing in Course Detail Level is typically the "Stick Symbol", which has it's own Subcategory VG settings. The actual geometry of the Structural Member is typically only visible in Medium and Fine Detail Level View. The geometries visibility conditions are assigned in the Family through Visibility Settings.
