Truss and walls
4 ANTWORTEN 4
Nachricht 1 von 5
htews
503 Aufrufe, 4 Antworten
Truss and walls
New to creating a roof truss and adding it to the model.  seems like the truss end points want to 'snap' to the center of the end bearing walls.  is there a way so it doesn't snap/join to the wall?
4 ANTWORTEN 4
Nachricht 2 von 5
htews
als Antwort auf: htews
figured it out.
layout the truss in plan and then in section, raise the truss, extend the ends to where you want it and lower it back down.
Nachricht 3 von 5
pavlo_malkhozov
In Revit 2024.2, I am experiencing the same issue with trusses. The trusses snap to the center of the wall (which has multiple external layers), and I cannot make any adjustments. I need to snap the trusses to the center of the core wall. Currently, I have to spend a considerable amount of time editing truss chords because the truss ends only work automatically, and I cannot manage them within the wall body at all.
Nachricht 4 von 5
pavlo_malkhozov
Revit 2024.2 Your method does not help at all. When I copy the truss back down to the wall body, the truss is snapped automatically to the geometric center of the multiple-layered wall.
Nachricht 5 von 5
jay_colcombe
Is there an option to select the end of the Truss or Node (Tab or Right Click) and then use disallow join?
Jay Colcombe
Autodesk Certified Instructor
