Truncating Revision Schedule with a Calculated Value
2 REPLIES 2
mshamalla
283 Views, 2 Replies
Is there a way to truncate a revision schedule by using a calculated value?
For example; there are 12 revisions that have been issued but the revision schedule only fits (graphically) in a space for 6 revisions.
Has anyone used a calculated value in the revision schedule title block template to only show the last 6 revisions when loaded into a project - leaving off the ones that don't graphically fit in the schedule (the oldies that nobody cares about)?  Before I start pulling my hair out trying to put together some calculated value - trying to figure out if its possible.. or a fools errand.
How are you dealing with revision schedules that get crazy long? Do you merge and delete? Do you split and move the schedule to another location?
Tags (1)
2 REPLIES 2
mshamalla
in reply to: mshamalla
May have just found my own answer.. mildly embarrassing.
Is this how you do it?
Open Title block
View > Schedules  > (click on Revision Schedule)
Change "Family: Title Blocks" to "Schedules: Revision Schedules" (next to Edit Type in Properties)
Go to Appearance > should be pretty straight forward from there..
Finding this just makes me soo happy, .. I love this program..
Define the Height of the Revision Schedule | Revit 2017 | Autodesk Knowledge Network
Yes you have found right settings. That's is how I too set the revision schedule to a fixed height to fit in the titleblock.
