Is there a way to truncate a revision schedule by using a calculated value?
For example; there are 12 revisions that have been issued but the revision schedule only fits (graphically) in a space for 6 revisions.
Has anyone used a calculated value in the revision schedule title block template to only show the last 6 revisions when loaded into a project - leaving off the ones that don't graphically fit in the schedule (the oldies that nobody cares about)? Before I start pulling my hair out trying to put together some calculated value - trying to figure out if its possible.. or a fools errand.
How are you dealing with revision schedules that get crazy long? Do you merge and delete? Do you split and move the schedule to another location?
Solved by ToanDN. Go to Solution.
May have just found my own answer.. mildly embarrassing.
Is this how you do it?
Open Title block
View > Schedules > (click on Revision Schedule)
Change "Family: Title Blocks" to "Schedules: Revision Schedules" (next to Edit Type in Properties)
Go to Appearance > should be pretty straight forward from there..
Finding this just makes me soo happy, .. I love this program..
Define the Height of the Revision Schedule | Revit 2017 | Autodesk Knowledge Network
Yes you have found right settings. That's is how I too set the revision schedule to a fixed height to fit in the titleblock.
