I hope this message doesn't make a duplicate. I could not find any answer to my problem.
I'll try to explain in the clearest way:
I created a custom made door with the following method: first I created "the general opening" (1 family), then the "frame" (2nd family) and finally the "panel" (3rd family). I "charged" the frame into "the general opening" and it's fine (I can select it, adapt it etc.). When it comes to the panel, I charge it the exact same way into" the general opening" but when I align it, I cannot select it anymore. I redid it several times (I even redid the whole "panel" family just in case) but I still have the same problem.
Did anyone experienced the same thing?
Perhaps, I am not doing it the easiest way...I am a REAL beginner with revit and I am struggling a bit with it. Is there anyone here who knows how I can learn it the best way?
I hope I was clear. Let me know.
Big big thanks in advance,
Have a nice day_
Seems to me you're using too many nested families, share your door family to have a look.
Are they all the Nested Families built on the Wall-Based Family Template. Make sure to delete the "Opening" from the Nested Families. Only the Host Family should have an Opening.
