Per my screen shot, I have assigned all of the sub-components of my wall structure to have different layer names with corresponding colors. When it makes the .dwg it puts all of the wall components on the same A-WALL layer (magenta), despite being set up differently in the Export Manager. Can anyone shed some light on how to fix this? I really only want the core boundary of the structure to stand out, and have the other layers less pronounced... but this is giving me all or nothing?
Gelöst! Gehe zur Lösung
Gelöst von Base12. Gehe zur Lösung
Modify Walls/Exterior and Walls/Interior.
...based on Wall Type's Function setting.
Thanks for the suggestion - that was partly the answer. I realized (after looking at it for WAY too long) that I had failed to duplicate the info in the Projection columns into the Cut columns.
I should note that only four of the layers in the Walls subcategory seem export to .dwg layers: "Common Edges" (basically everything inside of your wall, no matter how many components you have defined), "Walls/Interior" , "Walls/Exterior" which are the innermost, and outermost lines, no matter what component they are, and "Cut Pattern". So there does not seem to be a way to control the layer color of the individual components (structure, substrate, finish, etc) within a wall? I'm not really sure why it breaks the export dialog into so many subcategories when they don't seem to do anything?
