Trouble with create parts
nechamaPUTL2
nechamaPUTL2
Hi Everyone!
I have a Dynamo Script that creates parts.
Pretty often I get a 'can't create parts' error, for some of the elements.
Does anyone have ideas/ suggestions of what causes this, and how to make sure it won't happen?
For example- I know that a floor that was modified with the modify sub elements option will give me such an error.
Question is- do you know of other similar causes that will cause such an error?
Waiting to hear back from you...
ralphdenhaan
Maybe you can check this page? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Invalid-shape-foun...
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
anze.kumar
If you divide elements to Parts depending on reference planes - they must intersect the element. Otherwise no clue, usually it is the inability of revit to create geometry of the Part. So either it is very small or it does not have a reference to divide it.
