Trouble importing obj 2023 files into revit 2024
2 ANTWORTEN 2
Nachricht 1 von 3
claol001
190 Aufrufe, 2 Antworten
Hi all,
I'm trying to import Sketchfab downloads (2023 obj files) into my revit 2024 project. Downloading is fine, I'm unsure why when I try open the downloaded files it tries to open revit 2023 (not downloaded on my laptop so shuts down).
Is there a way I can get a 2023 obj file into my 2024 revit project?
I only need them for rendering purposes in Enscape
Could someone please help as soon as possible. Thank you!!
2 ANTWORTEN 2
Nachricht 2 von 3
theslacollier
als Antwort auf: claol001
To import OBJ files from Sketchfab into Revit 2024 for rendering purposes in Enscape, you can follow these steps:
Convert OBJ to a Compatible Format: Revit does not natively support OBJ files. You must convert the OBJ file into a format Revit can import, such as DWG or FBX. You can use software like Blender, Autodesk 3ds Max, or online converters to perform this conversion.
RVT to the max
Nachricht 3 von 3
handjonathan
Hi @claol001
Thanks a lot for posting your question to the forums!   Has the solution suggested by @theslacollier helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
