I cannot find AutoCad link when I link in Revit. Is there any suggestions of how to move AutoCAD to correct place for importing?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
First, try link the CAD file center to center. If it still doesn't work, then you need to open the DWG and do a ZOOM EXTENT to see if there are any elements too far from the area of interest. If so, delete them and relink.
Hi @Anonymous
Thanks for posting on the Revit forum.
Importing a DWG into Revit prompts warning: "Some numerical data within the imported file was out of range. This numerical data has been truncated."
The possible cause is that the dwg file is corrupt.
Please follow the steps below to clean up the AutoCAD file and re-import it:
If the drawing persists with problems, try the following steps:
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi Viveka,
I have got similar issues despite following all of the instructions. My CAD Model has multiple dynamic blocks drawn in 3d (all different geometries are used - Solids, Meshes, Faces & Surfaces, etc)
I can append the CAD model in navisworks along with all the rest of the Project files but when I try to import my CAD Model into Revit, it gives me below errors.
'Some numerical data within the imported file was out of range. This numerical data has been truncated.'
'A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing.'
I have tried to convert the CAD Model in IFC format, it failed to convert the CAD Model in IFC.
Could you please suggest me a way to get the CAD Model imported in Revit?
Kind regards
Nik
Hi I dont have a specify on screen option to uncheck. Im using Autocad 2020. Im tryinfg to import cad but its not visible. I've attached the warning
Actually its hidden but im unable to unhide it. Any ideas??
